Sometimes when making a new layer, once I have named it and pressed enter, the name will revert to "Layer 1" and I won't be able to use it or do anything with it.
The Layer Description changes to what I selected but the Layer Name does not.
What would be causing this?
Solved by jayhar. Go to Solution.
Using Autocad 2019 on Windows 7
Nothing has been changed on my PC and a colleague questioned this issue earlier today as well so it's not just my computer/software
<<<<<Sometimes when making a new layer, once I have named it and pressed enter, the name will revert to "Layer 1" and I won't be able to use it or do anything with it. >>>>>>
after revert to "Layer 1" close Layer and Reopen again you can see actual name you given.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved. ?
Thanks You
Jayhar.M.J
I also have same issue working in AutoCAD 2015, i just close & reopen Layer properties it will solve. so i did not think more.
here the command seen in AKN
SORTORDER (System Variable) set to <0>
http://help.autodesk.com/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-0CF4F029-C5C0-4B79-BEE8-0B0EE706...
About Filtering and Sorting the List of Layers
http://help.autodesk.com/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-5818FE81-B822-45AC-BAB0-3517376E...
Jayhar.M.J
