Explain in more detail what you are seeking please: if you only want to see what is loaded in your session then start CUI command then click on the pulldown and or expand the section shown below
I would like knowing which are the available menu in autocad. i was not aware of the existence of "express" menu for example and i would like to know if there are other. thank u
There is no limit and you can create your own!
In cui command dialog, as mentioned above, you can see which GUI components are loaded now.
Your question is easy, but the answer is not such simple.
Standard ootb loaded is not the same as
Standard ootb displaying
and not the same as available in Standard installation.
Plus, unlimited custom cuix
@mrcdaros as @cadffm stated you can create your own menu and here's instructions on how to create your own partial menu:
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-55B0E62E-9F40-4A95-BCE6-180EB47C9DDD
@mrcdaros Do you still need help with this, or did one of the responses solve this issue for you?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
