Hello everyone, i need help. I have problem in my architectural ticks in autocad 2020. The architectural ticks is not like a solid filled rectangular that shown at the dimension pre-settings. It just appeared like rectangular lines. Is there a way to fix this issues or something that i can set in the settings? I have found out about the shortcut key such as fillmode and stuff on the forum before ( i believe the article forum posted in 2007 ), with the same issues as me. I have tried the shortcut, however it does not work at all and nothing happened.
Note : Attachment 1 : Architectural ticks with rectangle lines (not solid)
Attachment 2 : Architectural ticks with solid rectangular in pre-settings
I set the architectural ticks in larger size to ensure that people can see the differences.
the shortcut key such as fillmode and stuff ?
Where is this shortcut key you're referring to?
Try FILLMODE use 1
Hello @Patchy ,
For the fillmode command, i just wondering when i am going to type the command? Is it like this steps?
1. type fillmode command and type 1
2. Put in dimension in certain area
Or it is something else?
Thank you for helping me in this problem.
With regards,
Madeline
I have tried the fillmode command with the steps that i used on the reply post before, however nothing happened. Not sure if i had done it right
Fillmode will not fill if the UCS is not PLAN.
Check to see if your dimensions are on PLAN view.
You need to be in a 2D view for the ticks to be filled:
Enter "-VIEW" at the command line, then select "O" (orthographic), then "T" (top).
