AutoCAD Forum
2015 Odd extra lines appearing
8 REPLIES 8
Message 1 of 9
David-cad4theatre
6623 Views, 8 Replies
I've opened a drawing from someone else, created in AutoCAD,  in AutoCAD 2015 and appear to have a lot of extra lines shooting off in strange directions. If I zoom right out, they disappear but reappear when I zoom back in
Has anyone else experienced this? Or is my graphics card about to die. This is on my laptop and I have yet to check on my home PC
Screenshots below, thanks in advance
David Ripley
cad4theatre
8 REPLIES 8
Message 2 of 9
Hello
YES they are some strange graphic problems with 2015 ...
1) Have you updated your graphic card driver ?
2) Have you tried to run with LINESMOOTHING = 0 (OFF) ?
3) Have you tried to run with LINEFADING = 0 (OFF) ?
4) Have you tried to run with Hardware Graphic Acceleration DISABELD ?
Have a NVidia graphic card ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 9
Pat
LINESMOOTHING cured it
I guessed it was something like that - something to add into my coursework, I guess
DAvid
Message 4 of 9
Hello
You are lucky ...
Patrice BRAUD
Message 5 of 9
Hi David, May I know the graphics card and driver of your problematic system? Thanks!
Christopher Chen
AutoCAD Test Development
Message 6 of 9
howdylee903
in reply to: chenchri
I have the same issue for ACAD 2014. A forum seach for this version doesn't get any results/answers. "Linesmoothing" doesn't work in 2014 (no such command).
Any ideas for 2014?
Message 7 of 9
in reply to: braudpat
thanks linesmoothing turning off works
Message 8 of 9
in reply to: David-cad4theatre
try VSE (VSEDGEJITTTER)(ENTER) MAKE VALUES AT 0.
David Ripley
cad4theatre
Message 9 of 9
try turning off "linesmoothing"just type in the command line and select off
thanks
salmen
”Boost
