Hi
I would like to create a block from an existing drawing and put it into a new drawing. When I come to insert it into a completely new drawing its not there, how do I do this please? How do I save blocks into a folder, to keep everything organised? Working on Macbook Pro with AutoCAD 14. Most gratful for you help.
ageyreader
Welcome to the Autodesk Forums!
On Mac you can use traditional method - WBLOCK command to create block from:
At the top left of dialog you need to pick on "Change" button and navigate to the folder where you want store blocks.
Another mot hod on Mac is to create as many blocks as you need in one drawing, save this drawing to the some folder on your Mac, than use "Content palette" to add this drawing to an existing Library or to the new Library. You need to add it with option "This drawing contains multiple blocks" when prompted.
Maxim
