First time poster, long time lurker. I scoured the forum hoping to find a solution but did not come across an answer.
I recently loaded the BreakObjects21.lsp without any hiccups. The commands appear when I type them in but after selecting the objects, nothing happens. I did read somewhere that not all LSPs work on Mac vs PC. Really hoping that's not the case for this one since these commands would expedite my project greatly. Any help would be greatly appreciated. Thank you!
Solved by pendean. Go to Solution.
Hi @vlam104Q84D ,
This AutoLISP routine uses VL-functions (Visual Lisp) not available in AutoCAD for Mac, so you cannot use it on Mac.
Many of those separate functions exist in some form/function as individual old-style no-popup LISP routines all around the web, find those individually to use. I am attaching "breakalllines" for example that you can test.
HTH
Thanks for the help!
I also found another work around that has been very helpful.
I will attach for anyone else who's searching/needs it.
The prompts on CAD don't say but first select the item(s) you will use to cut/break, hit enter, then select the item(s) that will be cut/broken, hit enter.
