AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Display AutoCAD Dimensions in Inches
6 REPLIES 6
meangus
3149 Views, 6 Replies
can anyone tell me how to set my dimensions to read out in inches, not feet and inches? I'm using AUTOCAD LT for mac.
 thanks, m
@meangus, john.vellek has edited your subject line for clarity:dimensions
6 REPLIES 6
maxim_k
in reply to: meangus
Modify dimension style settings on the Primary Units tab - set Unit format to "Fractional" and Suffix to " :
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
Hi @meangus,
Did the solution from @maxim_k fix answer the question or are you still having problems getting the units displayed the way you would like?
Please update your post with your results.
Please select the Accept as Solution button if a post fully solves your issue or answers your question.
John Vellek
meangus
worked beautifully! thank you for always helping out!
bananaking365
Hi, in the solution above, there will be an inch symbol (") after an angular dimension (i.e. 60°"). Is there a way to solve this?
Thank you.
maxim_k
in reply to: bananaking365
Hi @bananaking365 ,
Yes, you need to create separate dimension "sub-styles" for linear and angular dimensions.
Start with general dimension style, and add new style for Linear dimensions:
Now add new style for Angular dimensions:
Now edit Linear "part" of dimension style:
- add suffix :
Save changes.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bananaking365
in reply to: maxim_k
Thank you Maxim! That worked beautifully!
