I'm having difficulty getting the wire sequencing to work correctly. I completely deleted the wire and re-drew it connecting only to 4 components, but when I go to do the wire sequencing it is still showing the other components that are no longer on that wire network. Am I missing a step?
Solved by dougmcalexander. Go to Solution.
Did you delete using AutoCAD erase or AutoCAD Electrical delete? Try a database rebuild. Go to the command line and type AEREBUILDDB, press Enter, and click Full Rebuild.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Glad that helped. Kudos are appreciated.
Anytime you catch yourself using an AutoCAD command on an Electrical drawing, rebuild the project scratch database.
Hint: Use the CUI Editor to add the Rebuild/Freshen Database command to your ribbon. I suggest locating it on the Project Tools as shown in the attached screen capture. After you move it up to the ribbon panel click in the Name field at the right of the CUI Editor and name it Rebuild DB. Set the buton style to Large with Text Vertical. (see attached screen capture)
Doug McAlexander
