AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
issue that came up with using WIPEOUT command....
4 REPLIES 4
418 Views, 4 Replies
So, I created my panel layout symbols, and added a WIPEOUT, with it being 'behind' the object.  My problem is, for some reason, when I bring in the symbol, it works all great for a while, and then, in explicably, it STOPS working.  Meaning, the wipeout is no longer doign its job.  I've been trying to replicate it, and I CAN, i just can't determine WHEN it happens.  And nothing I do, short of rebuilding the symbol with the wipeout again, seems to fix it.
Its nto a critical function, merely cosmetic.  It IS however annoying, as I know it works, it just keeps dumping on me.
Anyone else have this, or a similar, issue?
Thanks again
Doug
4 REPLIES 4
cbenner
I see it all the time, randomly.  Editing the block and putting the wipeout BACK under the entities, will fix it for a while.  But you shouldn't have to keep doing that if that's how the block was designed.  I don't see this in regular Autocad, only in Electrical... and primarily with blocks brought in through the Icon menu and catalog.  Placing a block the old fashioned way it usually works fine (usually).
I just usually assume I'm not using it right, and I end up exploding my din rail and trimming it out.  Can't mess around with wipeouts all day when I have a panel layout to get out.
ronbotkin
Have you tried using Tools\Draw Order and moving the symbol back to the top?  Sometimes I have to use the Bring Above Objects or Send Under Objects to get the symbols to display correctly.
Ron
dougmcalexander
No need to explode the blocks.  Just type regen and press enter.  If that doesn't work go to Home>Modify and use the Send to Back or Bring to Front utility.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
in reply to: dougmcalexander
LIke a dolt, I didn't consider lookign for draft order under the menu ribbon.  I was used to the rt-click/draft order, and in ACADE it isn't a rt clicking option.
So, having been successfully pointed in the correct direction, all things works swimmingly.  Thank you for the nudge guys.
Doug
”Boost
