When placing a component panel footprint on top of a dinrail footprint it does not cut the dinrail can this be done in Acade and how?
Solved by rhesusminus. Go to Solution.
Solved by trabuck7. Go to Solution.
You can insert a WIPEOUT into your component symbol and change the draw order of the wipeout to the back of the drawing.
I've created some code and a video to make this easier. You can find both here:
https://knowledge.autodesk.com/community/screencast/cbbe4fac-afac-4938-add1-a9148730ff43
