I am currently trying to find out another to show jumpers between terminals. Currently we have our terminal strips laid out and have a jumper report next to the terminals. Attached is an example of one of the ways that we are showing jumpers, the other is to just have the text, but we can only do this if the customer allows more than one wire per terminal. What I am looking for is a way to show a graphical representation of the jumper comb or internal jumper, this has come after a customer request to show a representation of a jumper. Also I was wondering how other people are showing jumpers, if they are just using the table of have another way of doing it. Any info would be helpful. Thanks in advance.
I am using Doug McAlexander's method (ecadconsultant.com) look in the tips section under "power bus".
This method takes care of the schematic and panel layout.
Thanks for the info. However I have already come across this while doing research on the matter and deemed this not to be a viable solution. Our internal jumpers are almost never a set distance all of the time, I would have to create a block for every jumper from 2 to about 20. The other problem is that we do power distribution across fused disconnects, Weidmuller ASK1, and lever disconnects, Weidmuller SAKR type. Both of these will only allow for an external jumper comb. I may just have to look in to doing a parametric block for a solution. Again thanks for the info on this.
Have you spoken to your Weidmuller rep. I managed to get a CD with cad dwgs for most of their terminal blocks and accessories from our rep. I just added the appropriate attributes to the blocks as I used them.
We tend to use the screw in jumpers here but the push in ones should be easy to do, no matter whatever the length.
At the first jumpered terminal, insert a jumper block that includes all the attributes to make it part of the project. the rest of the jumper length could be indicated with two 'dumb' (No attributes) blocks repeated as needed. One for the pin in place and one for the pin cut off.
It's a little bit cumbersome but a lot quicker than having to do a custom block for each full jumper and a lot easier than having to redo a parametric insert if the client wants to change something..
Regards Brad
Brad Coleman, Electrical Draftsman
I actually have footprints for each type of jumper, screw in type, comb, etc.. You create them like you would any footprint. Mine are unique according to the manufacturer they represent. I pre-load the MFG and CAT so when I insert the jumper it is automatically added to the BOM without the need for a Lookup.
Hint: I also added icons to my panel menu so I can insert the jumpers using the icon menu.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Thanks for all of the info on this. I ended up with a dynamic block that arraied in the y axis and patterned when you dragged it down. Also included a flip and just copied and modified it to work with all of the variables that we use.
