I am trying to use the source and destination arrows in ACADE, but I am encountering a problem. I am using the third signal arrow style, and using the sheet and reference numbers to reference the drawing and location of the other arrow. The problem comes when I place a source or destination arrow on a vertical wire. ACADE rotates the sheet and reference numbers so they are facing left when I want them to face down. If I use the rotate attribute command, it just rotates the attribute in place and not around the center of the arrow like I need it to. Is there any way to fix this without rotating and moving each individual attribute every time?
Riley
Solved by jseefdrumr. Go to Solution.
