AutoCAD Electrical Forum
Report Generator Terminal list
3 REPLIES 3
testsubject
188 Views, 3 Replies
I have modified my terminals to include 3 description lines; DESC1. DESC2, and DESC3.
When I tried to generate a Terminal number list, I selected the description field to be included in the list. Only DESC1 is being displayed. The header for DESC2 and DESC3 are on the report but the details for each of these atts are not in the report.
Just passing on what seems to be a bug.
Robert Hanrahan
Weigh Right Automatic Scale Co.
ACE user since 1998
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
3 REPLIES 3
in reply to: testsubject
You're exactly right. These two attributes are not showing up in the TERMS
table of the project scratch database file. Issue has been logged.
wrote in message news:4905177@discussion.autodesk.com...
and DESC3.
Robert Hanrahan
ACE user since 1998
I am having a similar issue with TERM names. I have a device with 6 TERMs. Using 6 wires connected to each of the 6 points yields only 1 connection point in the wire to/from. In ACE 2005 each point would be called out separately in the wire to/from. Am I correct in assuming this is the same issue, manifested differently? Also would it be possible to know when this issue, as well as the negative Y axis issue be fixed? We are in the process of switching our licenses over to 2006, but with these bugs I only use 2006 to draw in (nicer interface) however I have to use 2005 to generate reports. Thanks!
Nickolas
Both the DESC2/DESC3 and the negative Y coordinate issues have been logged
as elevated priority. Can you send me a sample dwg with this 6-term issue? I
want to confirm that any resolution we propose and implement will work with
your sample. You can send privately to nate.holt@autodesk.com
wrote in message news:4916103@discussion.autodesk.com...
Thanks!
Nickolas
”Boost
