Is it possible to update the Revision black project wide in Autcad electrical without open each and every drawing typing the comand "vltrevblock". I have managed to update the project with a new Title block using swaup/update block.
We use Vault profesional Client. Any help will be apreciated, we have 4500 dwg files to update with our new rev block.
Solved by Peter_MullerNEBBL. Go to Solution.
I have found the solution.
Vault 2020 Help | Advanced Revision Table Configuration | Autodesk
Very easy, just need to RTFM! 😂
