Hi all,
I am a new use to ACE and I am putting together a title block. I want to use the same title block for multiple clients. Is there a way to replace the client logo based on a Project level attribute?
I know I can just do multiple templates but what fun would that be. :).
Thanks, Steven
Solved by rhesusminus. Go to Solution.
Solved by testsubject. Go to Solution.
You do not have to use multiple templates but might need to have a separate title block for each customer.
Assuming you create the titleblock with all the attributes you need you can use Swap/Update block on the titleblock project wide and it will change all the titleblocks to the new titleblock.
Thanks @testsubject , @jseefdrumr , & @rhesusminus for the thoughts.
I like the idea of XREF's but I have found when dwg files get sent to others it never seems to get there in tact.
Swap/Update block does make it easy to change the title block.
Thanks for the help,
Steven
