Opening an AutoCAD 2004/LT 2004 format file.
Substituting [simplex.shx] for [ELEGANCE].
Regenerating model.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
AutoCAD Electrical menu utilities loaded.
Autodesk DWG. This file is a Trusted DWG last saved by an Autodesk application
or Autodesk licensed application.
Command: (COMMAND "_.SCRIPT" "C:/DOCUME~1/PERTEC~1/LOCALS~1/Temp/ace19B.scr")
_.SCRIPT
Enter script file name <>
users\documents\pertech\compaines\cat\projects\winch
system\drawings\m40211\M40211-E-03.scr>:
Command: nil
Command: _.cmdecho
Enter new value for CMDECHO <1>: 0
Command: wd_scr_msg "========== Drawing 4 of 34 =========="
Command:
Command: wd_prnt_time_date
Searching BLOCK table for attdef "WD_TB"... Found. Title block=TITLE_BLOCK
Command: _.-PLOT
Detailed plot configuration? [Yes/No] : _YES
Enter a layout name or [?] : 'wd_chk4_layoutnam_oem "11x17"
"11x17"
Regenerating layout.
Regenerating model - caching viewports.
Enter an output device name or [?] :
Enter paper size or [?] : ?
Available media sizes.
"Custom Size"
"Universal 8 1/2 x 14 in"
"‚Í‚ª‚«"
"8K"
"Double Postcard (JIS)"
"B5 (ISO)"
"Executive (JIS)"
"16K"
"US Index Card 5x8"
"US Index Card 4x6"
"Envelope A2"
"Envelope Monarch"
"Envelope B5"
"Envelope C5"
"Envelope DL"
"Envelope #10"
"11x17"
"B5 (JIS)"
"B4 (JIS)"
"A5"
"A4"
"A3"
"Executive"
"Legal"
"Letter"
Enter paper size or [?] : User-defined size
Restoring cached viewports.
Command:
.-PLOT Detailed plot configuration? [Yes/No] :
Enter a page setup name <>: _E
<_E> not found.
Enter a page setup name <>: _F
<_F> not found.
Enter a page setup name <>: 0,0
<0,0> not found.
Enter a page setup name <>: _YES
<_YES> not found.
Enter a page setup name <>: (c:wd_chk4_ps "C:/Documents and Settings/Pertech
LLC/Application Data/Autodesk/AutoCAD Electrical 2007/R17.0/enu/Plot
Styles/Jesse/Central Electric.ctb")
<(c:wd_chk4_ps "C:/Documents and Settings/Pertech LLC/Application
Data/Autodesk/AutoCAD Electrical 2007/R17.0/enu/Plot Styles/Jesse/Central
Electric.ctb")> not found.
Can not use None device for plotting.
Command: _N
Unknown command "N". Press F1 for help.
Command:
Command:
Automatic save to C:\DOCUME~1\PERTEC~1\LOCALS~1\Temp\M40211-E-03_1_1_0127.sv$
Command:
Last plot's settings retrieved from C:\Documents and Settings\Pertech
LLC\Application Data\Autodesk\AutoCAD Electrical
2007\R17.0\enu\Support\user\lastplot.tmp
Drawing saved in AutoCAD 2007 format.
Command: (COMMAND "_.SCRIPT" "C:/DOCUME~1/PERTEC~1/LOCALS~1/Temp/ace38E.scr")
nil
Command: _.cmdecho
Enter new value for CMDECHO <0>: 0
Command:
Command: _.-PLOT
"11x17"
Restoring cached viewports - Regenerating layout.
"Custom Size"
"‚Í‚ª‚«"
"8K"
"B5 (ISO)"
"Executive (JIS)"
"16K"
"US Index Card 5x8"
"US Index Card 4x6"
"Envelope A2"
"Envelope Monarch"
"Envelope B5"
"Envelope C5"
"Envelope DL"
"Envelope #10"
"11x17"
"B5 (JIS)"
"B4 (JIS)"
"A5"
"A4"
"A3"
"Executive"
"Legal"
"Letter"
Command:
<_E> not found.
<_F> not found.
<0,0> not found.
<_YES> not found.
Command: _N
Command:
Command: *Cancel*
How Do i get the get the project settings?>
