I am aware that there is another post with this same title, but it doesn't solve my issue.
I am making a template and I have done the following:
Then, I create a new project and add new drawing with the new template and the error comes up. I've worked on this for many hours, restarting the process entirely several times. The drawing appears to function normally and I am able to do title block updates. I just want this error to go away.
Thanks.
Solved by vwb483. Go to Solution.
About the Title Block Setup: AutoCAD Electrical 2024 Help | About the Title Block Setup and Update | Autodesk
After configuring title block, you need to create a block of attributes, including wd_tb.
And save the file in dwt format (drawing template).
When creating a new drawing, the drawing template is loaded.
The program finds a block and attribute wd_tb, which specifies other attributes and their correspondence to the project data.
After turning on my computer this morning, I opened the template and deleted the title block. Then, I purged it and inserted it again. I added the visibility set again and saved the file. The error doesn't appear anymore. It's very bothersome that this problem seems to be fixed and I don't know what caused that.
