AutoCAD Electrical Forum
Need help with associating a line to a layer
2 REPLIES 2
246 Views, 2 Replies
I've been stumbling around, and following the manual too!, but I cannot figure out how to associate a new line to an already existing layer.
Any ideas...?
2 REPLIES 2
dougmcalexander
You can use the standard Properties tool, grip the line and select from the layer list, or if it is a wire, you can use the Change/Convert Wire Type tool.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Thanks!! Much appreciated
”Boost
