AutoCAD Electrical Forum
BOM for AutoCAD Electrical?
3 REPLIES 3
1857 Views, 3 Replies
How do get a generate BOM when working in AutoCAD Electrical 2012 ?
3 REPLIES 3
KevinLi-Autodesk
There are two types of BOM reports (Schematic and Panel) in Autocad Electrical 2012, you can go to Reports tab in Ribbon, if you want to generate Schematic BOM report, then click Reports button under Schematic panel, otherwire click Reports button under Panel panel, then select BOM report name and follows the wizard to generate it.
Kevin Li
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
in reply to: KevinLi-Autodesk
Thanks for sharing this info! I just downloaded the 30-day trial and this software is amazing. Can you recommend any books I could buy for learning AutoCAD Electrical 2012. Thank you!
KevinLi-Autodesk
Go to Help in your 30 day trial version, especially on the Tutorials. Also you can find a pdf file in the Help folder in your install path in your disk, it is Autocad Electrical 2012 user guide, you can learn from them.
Kevin Li
Kevin-Hongyuan Li
www.autodesk.com
”Boost
