AutoCAD Civil 3D Wishes (Read Only)
Create Survey Point Group using Query Capabilities
3 REPLIES 3
bruce.jordan
513 Views, 3 Replies
Unless I'm missing something, the only way to add points to a Survey Point Group in the Survey Database is to manually check each point # you want. Looks like it's still this way in 2011.
It would be such a time saver if the Survey Point Group worked like the Point Group on prospector tab with the ability to query points based on point numbers, description, etc.
-Bruce
3 REPLIES 3
nmessina
in reply to: bruce.jordan
I would love to see the Survey Point Group Manager to be exactly like the Cogo Point Manager. The code exists, why didn't Autodesk make them the same?/
Nicholas, Messina Jr., PSM
It works exactly like Point Groups in Prospector, actually you make the point group in Prospector first.
Create the Survey Point Group and click the 'pick' icon at the top of the window and then select by Group on the command line. You can then select the point group you made in Propector.
The downside is that the points must be in the drawing?
I aggre that the same functionality should be in the Survey Toolspace.
Caleb
bruce.jordan
Hmm, interesting.
I don't get any points added to a Survey Point Group when clicking the "pick" icon.  Doesn't matter if I choose All, Numbers, Group, or Selection.
-Bruce
