I have my surface set to exclude everything above elevation 822.
But when I turn on "Triangles & Points" for this surface, I'm seeing points above 822. Why would it do this?
EDIT: I thought I'd give a little background info. This is a man-made lake. It's been drained and we need to regrade the bottom. Everything lower than 822 will be left as is. Anything higher than 822 will be cut out. Then there will be little islands (6 of them) that I'll create using feature lines. The bottom of each island will be at 822. Everything between the bottoms of these islands and the existing 822 contour should be FLAT at 822.
The surface I'm showing you will be an intermediate surface only. I pasted my existing surface into it and then set it to exclude everything above 822.
My intention is to set this surface to NoDisplay and then create a FG surface which will consist of 1) this intermediate surface pasted in and 2) the island featurelines.
Don Ireland
Engineering Design Technician
Solved by Jeff_M. Go to Solution.
😞 That's not what I wanted to hear. But thanks. I'll get working on that.
Don Ireland
Don,
Looks to me it's due to the fact that Surface EG-1 was created using a Snapshot.
This Snapshot is then Pasted into the EG-Below822 Surface.
Tested this in Tutorial file Surface-4C.dwg the XGND surface does honor the Elevation filtering if
elevations >100 are excluded.
Once I create a new Surface & Paste the XGND into new surf. then any elevation exclusions won't
work on the pasted surface. If the exclusions are applied to XGND & both surfaces are rebuilt, now that
new pasted surface is honoring the elevation exclusions. HTH
I've never used snapshot (not that I know of anyway) and I created the EG surface. The file that I'm working with has the EG surface referenced in. So that I could upload the file for examination, I opened a new file and promoted the surface into the new file (so that it's active).
But the file that I'm actually working with still has the EG surface referenced in.
I took Jeff's advice and extracted the 822 contour. I've since realized that I'm going to have to do that anyway. Where my proposed work crosses the 822, I need to trim it back. C3D got REALLY CONFUSED otherwise because I had two 822 contours crossing each other.
Don Ireland
Grrrrr. This is really annoying me now.
I created a new outer boundary for the intermediate surface (based on the 822 and modified to go around my islands). Then I added my boundary to the surface.
The surface is STILL showing contours/triangles outside of the boundary.
The Cyan colored shape is the boundary. The other two surfaces are set to NoDisplay (the ONLY surface shown is the one in question).
Since promoting the surface in seemed to have caused an issue, I'm going to try posting my actual file.
Also--this is in C3D 2012.
Don Ireland
dwg contains broken reference causing EG-1 surface to be out of date.
And now we know how, right?
Joe Bouza
Don Ireland
Ok Here's the source dwg file for the EG-1 surface.
Don Ireland
@doni49 wrote:
Thanks Joe. Ironically about an hour or so after I posted my reply in the message you linked to, one of the engineers in my office brought me this lake grading task.
But no as I said above, even though I've added the cyan polling (which Is closed) as an outer boundary, the triangles and contours continue to go beyond it.
POLYLINE. Stupid autocorrect! 🙂
Don Ireland
Ok this is WEIRD! I came in this morning and delted the boundary from the surface definition intending to recreate it. When I pick the polyline, I get a message about an illegal self-intersection. But this same shape WAS used yesterday -- it just wasn't cutting the surface off.
Don Ireland
I think I've narrowed down what it's having trouble with. Remember: I originally exported contour 822. Then I modified the resulting polyline to go around two locations of proposed work.
In my troubleshooting efforts, I eleminated ONE of those work areas and imported the resulting polyline -- it came in with no problem (and the surface gets trimmed the boundary as expected.
But If I attempt to put back my work area at this location, it tells me there's an illegal self-intersection. I used this tip to "walk around" the polyline at this location and I don't see any place where it intersects itself.
Don Ireland
RESOLVED.
I still don't understand WHY it was having trouble. But I forced ACAD to recreate the boundary shape from scratch and C3D accepted the new boundary without complaint and it's now trimming the surface as expected.
Here's how I forced it to recreate the boundary:
Don Ireland
Thank you. I had the same situation trying to exclude certain points greater than elevation A and I looked incompetent in front of an engineer. The surface would not change after the rebuild.
I will have to jot this down when pasting surfaces.
