Civil 3D Forum
Is there some way to turn off contours above a certain elevation?
15 REPLIES 15
Message 1 of 16
sbrasher
8001 Views, 15 Replies
15 REPLIES 15
Message 2 of 16
Citadel2012
in reply to: sbrasher
You could extract specific countours and use them as surface boundaries (working this would vary greatly on the contour geometry).
______________________________________________________________
To Err is Human; To Really Foul Things Up Requires a Computer.
Message 3 of 16
ccoles
You could also extract a contour at the cut-off elevation and use it as a surface mask. It will not be dynamic, however.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Message 4 of 16
Joe-Bouza
You can create a style that displays contours at different colors. therefore you could display the unwanted elvations a color that does not plot
Joe Bouza
Message 5 of 16
Joe-Bouza
To be more specific: under surface propertires>> analysis>> contours; choose 2 intervals  and set the elevations of the unwanted and wanted. pick a no plot color (255 in our shop) for the major an minors, and plot colors for the other major minors. Important! edit the surface style >>contour tab>> contour intervals>> say "True" to use color scheme.
totaly dynamic
Joe Bouza
Message 6 of 16
If it needs to be dynamic, limit the elevation in the surface properties (Definition>Build>Exclude Elevations greater than).
Message 7 of 16
Joe-Bouza
I'd be carefule with that approach.
That will alter the triangulation and the results may not be the exact surface.
Joe Bouza
Message 8 of 16
rkmcswain
in reply to: Joe-Bouza
You're right --- there is a difference in limiting the data to a certain range vs. limiting the _display_ of the data to a certain range.
R.K. McSwain     | CADpanacea | on twitter
Message 9 of 16
Joe-Bouza
in reply to: rkmcswain
Thanks for confirming that.
Joe Bouza
Message 10 of 16
doni49
totaly dynamic
I'll take Joe's suggestion a step further.  Create a linetype that places 1 single dot at a really high spacing.  Use that linetype for the contours that you don't want to see.  You shouldn't even see them on screen (unless acad forces it to display a continuous linetype).
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 11 of 16
doni49
totaly dynamic
Joe,
Maybe you can share some info as to how you did that?  I attempted to use it but apply the linetype suggestion I made earlier.  I can't even get it to change contour colors.
I created two contour ranges:  one below and one above 570.  Then I made the second one magenta and the first green/cyan.  But no matter what, they remain RED.
Don Ireland
Message 12 of 16
doni49
in reply to: doni49
P.S. I don't see the setting you mentioned -- maybe that's why?
EDIT:  After posting that, I got to wondering if there might be some other place to find that setting.  I found it.
Don Ireland
Message 13 of 16
Joe-Bouza
in reply to: doni49
pardon my mistake, Don. The setting is under contour ranges >> color scheme = true
Joe Bouza
Message 14 of 16
doni49
oh.  Thanks.  Having found the setting, I applied the linetype suggestion.
It does reduce the visibility of the contours (on screen) and Joe's suggestion will make the contours not plot at all.
Magenta & Dotted is below 570 and Cyan/Green & continuous is above 570.
Don Ireland
Message 15 of 16
sbrasher
Thanks for the creative solution! Worked like a charm 🙂
Message 16 of 16
Joe-Bouza
HTH
Please select "accept solution" so other readers may be aware of your solution
Joe Bouza
Rail Community
