While I don't have a detailed pipe network longsection that would help you, there are some samples you could check out in the tutorial folder that come with civil 3d.
In regard to setting up profile views, search this forum for "House of Style". The search will turn up a PDF document that James Wedding presented at Autodesk University a few years back that covers profile views and the various styles which really helped me out when I started setting up civil 3d.
Generally, if you can draw it manually, you can setup style to have a profile view appear the same. Sometimes it just takes a bit of work.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
