Civil 3D Forum
Welcome to Autodeskโ€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Point Number Issues in C3D 2013
4 REPLIES 4
521 Views, 4 Replies
Argh!!!!!!
It doesn't matter where you set the Next Point Idenity
In the Create Points dialog Box or The Command Settings
Choose Create Points Interpolate and it resets to the lowest point number avaliable.
Or.....
Renumber some points that got entered wrong (From above problem)
now try to create a point manualy
the numbers already exist so instead of renumbering automaticly all you get is NOTHING!!!
You have to reset the next point number. And if you enter a number that exist all it tells you is
"Point Number Must be Unique"
AUTODESK FIX THIS PLEASE!!!!!
As if there aren't enough time wasters built in ๐Ÿ™‚
4 REPLIES 4
BrianHailey
Did you submit this to Autodesk support?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Look all over.
Can't find a place to email Autodesk.
Jeff_M
I think THIS is the same issue, which Autodesk is aware of.
Thats it exactly!!
Rail Community
ย
ย
