Civil 3D Forum
How to - Insert Taper Road from 2 Lane to 4 Lane Corridor
4 REPLIES 4
2664 Views, 4 Replies
Can Anyone Help me?
-newbie
4 REPLIES 4
You need to have your assembly transition in width by creating and targeting an entity like a polyline to define the extent of the widening.  Once you create the polyline then you can select it as a width or offset target through the Corridor Properties > Parameters tab.  The subassembly that your using needs to support transitions.
I suggest that you look at the following tutorial to get some background on creating a transition:
Tutorial: Creating a Corridor with a Transition Lane
thanks a lot @gjrcmb.
i got it now. 🙂
You're welcome.
Rail Community
