this is my c3d using 2d wireframe view.
and, this is 3d realistic view. that so bad. rite? 😞
From what I can tell it looks like the Boundary for the Existing Ground Surface and/or the Boundary for the Corridor Surface has not been setup correctly. I believe it is probably the existing ground, but hard to tell exactly from the image. Once again I am going to refer you to the tutorials.
The first tutorial I am referencing is applicable to creating an existing ground surface boundary, but it would probably be good to go through all four exercises as opposed to just Exercise 4 referenced below:
Exercise 4 - Adding an Outer Boundary to a Surface
The next tutorial is more applicable to the corridor design surface boundary, and once again it would probably be good to go through all three exercises as opposed to just Exercise 2 referenced below:
Exercise 2: Creating Corridor Surface Boundaries
Hopefully that will help,
What does the Surface look like if displayed as Triangles?
Allen
Allen Jessup
CAD Manager - Designer
@gjrcmb
I have done surface & corridors boundaries, but still same result. 😞
@AlienJessup
this is my triangle surface view.
@gjrcmb
sorry, i'm cannot attact here.
the file is to large
can you give me your emel?
so can i sent you via emel 🙂
Just to show that the OP is not alone.... This is an ObjectView of a corridor I'm working on. Note all the strange shoots heading for 0,0,0. They all appear to be starting along the daylight lines. If you look close, there are other daylight slopes that have no hatching on them. This is using the Conceptual VS, the Realistic has the same issue.
And here is the surface created by the same corridor, note the anomolies are not existent here:
This drawing is ~40mb so cannot attach. I'm stumped as to what may be causing this.
C3D2012 SP1 Win 7 x64 12gb
Occurs on 2 pc's, one with an un-certified nVidia geforce, the other with a certified nVidia Quadro.
I remember running into the same issue when I had a corridor with subassemblies that were being transitioned across the baseline for say a left turn widening. This would result in a discontinuity in the feature lines at the locations where the feature lines crossed the baseline. Your situations do not appear to be the exact same issue, but I do recall the lines shooting off towards 0,0,0. When you look at the corridor feature lines in the suspect areas do you see discontinuities in the feature lines? In the corridor properties try turning off (unchecking) the feature lines that are correspond to subgrade subassembly points (Corridor Properties > Feature Lines tab) that are not needed for the top surface. I'll keep looking into this and let you know if I find anything else.
See following post:
C3D Corridor Glitch - Adding Render Material to Codes - Lines Appear to Infinity
Based on that posting, I was able to recreate what you both are seeing by applying a render material to the links in my Code Set Style. After looking at it a bit more, I can see that the problem occurs in my situation where one assembly ends and another begins or I have a median cross over as described earlier. So I don't really need to look at your files, since I essentially recreated the situation. In both of these situations the corridor feature lines shoot off to 0,0,0 when viewing in 3D only. So I am looking into whether there is some way to resolve the feature line issue. As far as what I previously indicated, turning off the subgrade feature lines will obviously not resolve the issue for feature lines on the top surface.
Possible workaround. What I did previously when I ran into this problem, was to create a 3D view using surfaces instead of corridors. I did this by opening a new file and creating a data shortcut to my existing ground and design surfaces, and then applying rendering materials to those two surfaces. If you are wanting to display different rendering materials for different roadway features you do have the option of creating separate surfaces for each corridor link via the Corridor Properties > Surfaces tab. An issue with this approach is where your design surface is in cut, the 3D display will not show your design roadway. So to get around that one you actually need to paste your design surfaces onto a copy of your original ground surface.
Can't seem to come up with a way to resolve the feature line issues I am seeing. Whether that is what you two are experiencing I can't say, but I suspect it is. I think you may need to go with the workaround I suggested in my last post if you are needing to present your roadways in 3D. Unless someone else has a solution or better idea?
In the corridor I showed, there are only 3 different assemblies, 2 for intersections and the other for the remainder. So, for me, it's not a transition issue. It seems to happen more where the daylight transitions from cut to fill and back, but it does occur other places too. I get the same results with, or without, all featurelines off.
Right now, this is just a conceptual plan for a racetrack, 2.5 miles in length. There are a number of infield areas, so trying to get surfaces of all the different materials will be painstakingly slow and tedious...and not worth it at this point. I showed the contractor a quick movie made with the Drive command...even with the anomolies he was sufficiently impressed. I just hope this gets corrected before it's time to do the final drawings & presentation.
Next weekend I will probably make up a small sample to submit with a support ticket.
