Civil 3D Forum
Help Files 2012
13 REPLIES 13
Message 1 of 14
neilyj666
1769 Views, 13 Replies
Help Files 2012
When accessing help in C3D 2012 a html file opens up e.g. http://docs.autodesk.com/CIV3D/2012/ENU/acad-search.html?query=drape%20image.
Does the help only search online for help files or are help files also on the local disk (in the event of no online access)??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
13 REPLIES 13
Message 2 of 14
neilyj666
in reply to: neilyj666
... and another thing:
In C3D 2011 the documentation was available in pdf versions (e.g. Best Practices guide, User Guide) have the pdf's been discontinued in 2012 as it all seems to be browser based now??
Message 3 of 14
AllenJessup
You may be interested in this thread. http://forums.autodesk.com/t5/AutoCAD-2011/How-do-you-use-Help/m-p/2971316/message-uid/2971316#U2971...
Allen Jessup
CAD Manager - Designer
Message 4 of 14
ctbailey
There is a new setting in the Options -> System tab, lower right hand section of "help"
You can check a box that says "Use online help... when available."
If you uncheck this box, the help system will pull the same documents from your local hard drive.  Interestingly, if you lose internet connectivity, the system will pull the help files locally even though this check box is checked.
_______
Craig T. Bailey, PE, LLS, PSM
Bailey Associates
www.bailey-associates.com
Message 5 of 14
neilyj666
....and the pdfs discontinued presumably????
Message 6 of 14
Those documents are up in the support section of autodesk.com:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16785133
Message 7 of 14
neilyj666
Yes they are - but no pdf versions
Message 8 of 14
corboto
in reply to: ctbailey
So what do you do if your 2012 installation doesn't include the option for online help?  See my screenshot.  Thanks.
Message 9 of 14
albionpjl
Oh thank goodness for this. Thank you for this information. I've been tearing out my hair trying to work out how to get offline help.
Our security means that all internet access has to go through a virtual desktop which of course my locally installed version of C3d cannot use.
Message 10 of 14
jefferyjensen
I'm also interest in getting a PDF version of the Civil 3D 2012 User's Guide. Yes, I understand the User Guide is available online at http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/topichead_d3e15057-0.htm
Autodesk provided the 2011 User's Guide in PDF at http://images.autodesk.com/adsk/files/civil_users_guide0.pdf and http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16766674
thanks for the help,
Jeff Jensen
Message 11 of 14
neilyj666
I think you'll be out of luck on this one unfortunately
Message 12 of 14
wfberry
in reply to: jefferyjensen
Jeff:
It goes something like this:
"In order for AutoDESK to maintain these extra low prices we have decided to eliminate the followng, PDFs , . . . . . ."
Quite frankly if you need an answer in a hurry I have come to the conclusion that Google hands it out in seconds rather than spend hours searching the Civil 3D help pages.
OF course this is just my opiinion.
Bill
Message 13 of 14
neilyj666
in reply to: wfberry
Google is certainly my first port of call for help queries in C3D these days
Message 14 of 14
Sinc
Google also seems to do a much better job at searching these forums than the built-in Search.
Sinc
Rail Community
