Hello All,
I have a drawing with existing and proposed surfaces. When I created the existing surface I added contour labels with no issue at all. Now, a few weeks later, I try to add contour labels to the proposed surface I get nothing. I have styles all set up in the drawing, I have even tried turning all layers on and thaw all layers before adding labels and I still get nothing.
I have searched Discussion Groups and haven't seen a solution to this specific issue. Any thoughts?
I couldn't attach the file because it is too large, will email if anyone wants.
Thanks for any help.
Solved by Jeff_M. Go to Solution.
You have not given much information about OS, Version, etc
Have you?
1. Restarted Civil 3D?
2. Re-booted computer?
3. Run a Repair?
Bill
Notice info below that should be entered thru :"My Settings" (Above Right)
I'll take a look at it for you. miff AT sonic DOT net
Windows XP 32bit
4GB Ram
Civil3D 2012
Have restarted program, restarted computer, still to no avail.
Have emailed the drawing to Jeff (below) will post an update on a solution.
