my mistake, just read the post about about Mike...must have skipped that
one...
Matthew Anderson, PE
On 6/1/2010 1:12 PM, Matt.Anderson wrote:
> I would assume that MIKE11 might be able to export to the Corp's SDF
> format if it can import...
> I hadn't seen a reference to MIKE11 in prior posts until today...
> MIKE11 appears to have a free CAD Plugin for MIKE.
> The other options might be to use a Point Cloud to pull in the x,y,z
> values of the results. [Just brainstorming...I need to download MIKE11
> to see what is possible...]
> On 6/1/2010 12:06 PM, neilw wrote:
>> AFAIK C3D will import an SDF that is generated by HEC-RAS GIS output
>> function. Unless MIKE 11 can output to SDF, I don't know how else to get
>> it's output into C3D. What did you have in mind Matt?
