How does one create an arc of a specified length? For instance, as shown in the appended sketch, we want to create an arc of, say, 500 feet in length with a radius of 1,000 feet. Logic suggested that we use the arc Center, Start, Length drawing routine, but this appears to calculate only the length of the CHORD of an arc, leaving us with an actual ARC length of 505.36 feet. That doesn't work for us.
So. How do we create an arc of a specified length?
Many thanks!
Solved by tcorey. Go to Solution.
From the Draw panel of the Home tab in the Civil 3D workspace, use the Curves functions, not the Arc functions. If you have an existing object, you can use Curve from end of Object. This will let you specify an arc length or chord length.
McL,
Don't forget the Curve Calculator:
Dave
Dave Stoll
Las Vegas, Nevada
rkmcswain wrote:
If you just want to use standard AutoCAD tools, draw a circle, break it, use Lengthen Total to set the length.
...or even simpler: draw an arc of R=1000 and any length, then _Lengthen suboption _Total.
Moreover, here's some code (source Augi):
;Written By: derek 'maverick' beals ;Version: a ;Date: 9-26-05 ;Description: this lisp routine draws an arc at given length & radius ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;Non-Standard Lisp Functions (defun rtd (r) ; Radians to Degrees (/ (* r 180.0) pi)) (defun dtr (d) ; Degrees to Radians (/ (* d pi) 180.0)) (defun tan (a) ; Tangent of variable (a) in Radians (/ (sin a) (cos a))) (defun sqr (a) (* a a)) ; Squares the variable (a) (defun fixx (realnum) ; Rounds the variable (realnum) to the next highest whole integer (opposite of the "fix" function) (if (> realnum (+ (fix realnum) 0)) (setq realnum (1+ (fix realnum))) (setq realnum (fix realnum)) ) realnum ) ;(setq variable (ssget)) - allows multiple picks in lisp ;(setq OS (getvar "osmode"))...(setvar "osmode" OS) - gets current O-snap settings @ front of lisp, then reestablishes them at the end ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;Lisp Programming starts here (setq LENG (getdist "\nEnter length of arc: ") RAD (getdist "\nEnter radius of arc: ") CEN (getpoint "\nPick center point of arc: ") ANG (/ LENG RAD) ANG1 (/ (- PI ANG) 2.0) ANG2 (/ (+ PI ANG) 2.0) ARC (entmake (list (cons 0 "ARC") (cons 10 CEN) (cons 40 RAD) (cons 50 ANG1) (cons 51 ANG2))) ) (princ)
