Shortcut menu for grips delay too short.
Running Windows 8.1 Pro, Civil 3D 2015 SP2, PP1.
Here's my issue and I'm certain someone has also run into this and can remember the system variable to change. What is the system variable that keeps your shortcut menu up longer so your mouse can actuall go over it to select the option.
I have a polyline. I select the polyline to edit a vertex. The grips light up. Now the vertx I want to edit is a curve, I want to turn it into a line. So I hover my mouse over the mdidle of the curve on the long rectangular grip and the shortcut menu comes up. My options are stretch, add vertex and convert to line. I want to convert to line. When I go to click on that option or just move my mouse away even just the tiniest amount off of the grip the menu disappears. Now in 2015 SP 1 that did not happen I had enough time to go over to the menu with my mouse and select the option I wanted. Now I can't even do that, the menu disappears so quickly that you can't get to it. I'm certain it's a system variable that controls the delay time similar to the one for your keyboard entry. What is that variable? That's what I need to know. If it's not a variable then how do I fix the delay time on this pop up menu.
Heidi B.
