I cant import a CSV file from work
Message 1 of 10
Hi, I am fairly new to autocad outside of school. I am trying to upload a csv i surveyed from work and while trying to import from file i keep receiving an error saying "no point file format match found" I have tried converting it to a txt and a few other file formats. also i have searched the forums and people have had similar issues but the fixes that work for them do not work for me sadly. i have attached the original file. If anyone could help it would be greatly appreciated. thanks.
EDIT - removed .csv file per poster request as it contained sensitive information
Replies (9)
Message 2 of 10
neilyj666
You need to create a new point file format that maps the fields in the csv so Civil can use it as it has much more detail than the standard PtNo, E, N, Z, D formats
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 10
annw2
The file also has a few extra lines in it.  Is this supposed to be a field book file or just a list of points?
I never worked with a surveyor who wanted to try the field book format.  They would all just give us the Point #, N, E, Z desc. format.
Hopefully another surveyor can give you more help.
Ann Wingert, P.E.
Message 4 of 10
annw2
I don't know aboout setting up new file import structures in 3d, but you can open your file in Excell, delete/rearrange the columns to one of the standard formats, and save back to a csv file.
Ann Wingert, P.E.
Message 5 of 10
Pointdump
T14,
Open up the CSV file in Notepad. Select whatever is between the columns and replace with a comma. And strip out any headers or lines with a point name instead of a point number. C3D prefers numbers.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 6 of 10
AllenJessup
First off. Do you need all of those columns? Most seem to have duplicate or unneeded information. It's easiest if you have a file that can be easily described. Delete the first line as it doesn't contain point information.
Second. You're going to have to use Point Names and let Civil 3D assign numbers. The first column is alpa-numeric. So that means Point Names. Start the Point Import:
Then you'll have to build an import format. You might be able to use both Raw and Full descriptions to bring in 2 of the description columns. In the Import Points window hit the Edit icon then New. Build the format by clicking on each column heading at the bottom and choosing the appropriate item. Then you'll have to edit your file to contain only those columns. It is possible to bring in more columns of information. But that is a much more involved process. I don't see that the last 7 columns contain info that would be useful in a cogo point.
Allen
Allen Jessup
CAD Manager - Designer
Message 7 of 10
AllenJessup
Hi Dave,
The file is comma delimited. Just way overburdened with columns.
Allen
Edited by
Discussion_Admin
Allen Jessup
Message 8 of 10
Pointdump
Hi back Allen,
I wasn't able to download his CSV file at work, so I just took a guess (SWAG) at the problem. When I download points from Access in a TSC3 data collector, that's what I have to do to make them useable in C3D.
Sounds like you've fingered the problem. A little Excel work should square things away.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 10
Thanks for everyones help. i found a way to get it onto my drawing!
i appreciate the quick responses.
thanks again
Message 10 of 10
AllenJessup
You're welcome. Would mind sharing which method worked for you or marking a post as a solution. That would help others who may have a similar problem in the future.
Allen
Allen Jessup
