ACA2015 I have an x-ref that wasn't showing up. I reversed the visible to outside the boundary and it all shows up. Reverse back to inside and nothing is visible. Just opened the project in old ACA2013 and it all shows up.
Obviously a bug in ACA2015. I don't have 14 installed so I can't check it there. Is there another setting or is this just another 'feature' in 2015?
Solved by ntellery. Go to Solution.
Just checked in fresh drawing x-refing both an acad drawing and someone elses ACA drawing and both work.
I've also tried several of my drawings and it's fine so perhaps there is a unique setting in some drawings so if anyone has any ideas of what setting might effect it. I suspect it's just an odd bug and not an intended feature.
I've been trying to read through the new features lists for 2015, and haven't stumbled upon any new commands or variables that pertain to Xref clipping....
Autodesk have confirmed that the drawing was corrupted and everything had to be cut & pasted into a new drawing.
I suspect the corruption was created by ACA2015 as when deleting the clip and opening back up in 13 everything was fine.
