i do not show 3d modeling as a workspace setting option. only architecture. i was able to right click and 'solid', etc will show up on the pull downs now. but does is matter not to have the 3d modelling workspace?
using autocad architecture 2012 and 2013
[ The subject line of this post has been edited for clarity by @handjonathan Original: Workspace - 3D Modeling option not showing ]
Solved by pothied. Go to Solution.
I think that I know what you are looking for. You want the 3D Modeling workspace that is available in the ACAD menu but you are probably working in the Architecture (ACA) menu. If that is the case, then it is pretty simple to get the 3D Modeling workspace into the Architecture menu using the CUI editor.
Type CUI at the command line.
Select the Transfer Tab at the top of the CUI editor
In the right side of the dialog, select the Open Customization File button and navigate to the folder where the CUIX files are located. On Windows 7 for AutoCAD MEP 2013, they can be found here:
C:\Users\<username>\AppData\Roaming\Autodesk\MEP 2013\enu\Support
Select the acad.CUIX file and select the Open button.
Select 3D Modeling in the Workspaces section and drag it to the left and drop it in the Workspaces section.
Select Apply and Ok
You should now have two workspaces – Architecture and 3D Modeling
I also created a short video with the steps that you can view here
http://screencast.com/t/Sj54gzMm5e0
I hope that this information solves your problem.
hi m using autocad architecture 2015.
Welcome to the community!
Are you using AutoCAD Architecture, rather than just plain AutoCAD? If so, and you are using a profile that has the ACA.cuix file as the main customization file, have you tried to to what @pothied suggested in the second post on this thread (marked by the original poster as the solution)?
Hi
I have AutoCAD 2017 LT, and my only workspace that I have is the drafting & annotation.
Any way I can get the 3D workspace working?
I tried searching for the ACA.CUIX but I only see a file named acadlt.cuix
Thanks a lot
The ACA.cuix file comes with AutoCAD Architecture, an architecture-specific program built on top of AutoCAD, and the subject software of this forum. It will not be part of the out-of-the-box content for AutoCAD LT. While I have not ever used AutoCAD LT, my understanding it that while it can open a 3D AutoCAD drawing, it is intended for 2D work and it most likely that the acadlt.cuix does not have a 3D Modeling workspace.
Worked perfectly, even on the networked PC's in the office. Just had to search the root folder for 'acad.cuix' as the structure was different with it being a mapped drive.
IT had installed full ACAD over the top of ACAD LT CUIX files and it had adopted them and dropped the 3d workspaces. Fully functional now.
Thanks very much.
hi, im currently using autocad 2019. But it doesnt show the 3d modelling menu. I cant find it anywhere in my autocad 2019.
Hi, I use Windows 8.1 OS and AutoCAD architecture 2014. Can you tell me the next steps for the same problem, because I'm not getting the options of 'appdata' after 'username' after C:\Users\<username>
Thank-you this was very helpful, although the instructions didn't follow the file layout exactly it got me the workspace I was looking for.
I am using auto cad 2023 and these steps aren't working for me. Is it in a different file for the version I have.
