These use to be on a layer that could be turned off. I don't see them listed in the wall style, display properties. I guess they have been removed, or moved. Is it possible to stil turn them display off?
Assuming that you are using a version that has the orange triangles of elucidation (solution tips), rather than the red circles of death (defect markers) that were used in older versions, you have discovered that the solution tips are no longer a display component.
You can still control visibility of solution tips. In the Options dialog, on the AEC Editor tab, in the lower left corner is the Solution Tips area. There are separate toggles for displaying solution tips when drafting and when plotting/publishing. So you can leave them on for drafting, and have them off (and therefore, not plotting) when plotting or publishing, which is the settings I would recommend. If you have Wall cleanup errors, chances are at least one Wall is not displaying the way you want, and it is easier to see that when the solution tips are turned on. But if you really want them off when drafting, you can do so.
That worked, thanks.
I like them to show, but some in the office don't. Just glad you can still control display & plotting.
Is there any other way to hide these. A user in my firm has followed the Options route, but they still plot. Could it be an xref issue?
It is a global setting. Are you using an older version of ADT that has the solution tips on a layer as David mentions?
With these settings, I can not replicate in ACA 2012.
