I highly agree with Doug on using SNAP as an error checking mechanism, and even
more with using rotated (and named) UCSes aligned with building axes as a way to
align your coordinate systems to a new local point. I've worked on relatively
simple plans with over 10 named UCSes.
I also use the PLAN (current UCS) command option a LOT. That rotates your view
to the correct orientation which makes drafting and dimensioning MUCH more
comfortable.
If you standrdize on a naming system (I used simple numbers, e.g. 1, 2, 3, 4...)
you can build a toolbar of UCS Restore -> PLAN command presets which will zap
you to the correct orientation.
Also, in my years of experience, I've never seen anyone draw a floor plan
accurately with SNAP disabled as a matter of course. Looking in closely at the
geometry always reveals tons of user input errors.
Matt
matt@stachoni.com
On Wed, 6 Jan 2010 09:18:15 -0800, Doug Broad wrote:
>So you're saying you have no right angles at all and nothing is on a snap
>grid and you can't rotate a ucs? I've never run into a building like that.
>It doesn't matter if some walls are curvelinear or at odd angles. Small
>snap still won't interfere. If you can't use grid snap, polar snap is still
>helpful.
> wrote in message news:6313207@discussion.autodesk.com...
>Using snap as you have suggested is great providing your building is
>square/rectangular i.e. all wall are perpendicular.
>It doesn't work however, if you have walls at an angle other than 90°.
