Suddenly, each time that I attempt to plot or print a drawing I get the message "Errors or Warnings Found". I open it up and it shows that the plot has been cancelled. I have run all of the "traps" that I know but to no avail. Anyone have a suggestion?
Ray Cox
Need more info.....what kind of plotter do you have installed.
Does the error warning say anything else that could identify the problem.
Is printer connected to computer or network.
Have you tried publishing to PDF/DWF and than print the PDF/DWF to the printer/plotter
Do you use a named page setup, or do you reset each time you plot.
Is it a large drawing file?
maybe you can post the file.
I did a repair run and that partially resolved the problem although I sometimes have to make two or three attempts before it finally plots. Thanks for your help. I will continue to attempt to solve the problm.
Ray
Ray, I seem to be having the indentical problem you experienced. Have you found a solution that has corrected the problem? You mentioned that you ran a repair run, can you explain how you did that?
Thank you
Barb
