I have created a live section in a view drawing, but when I drag the view drawing onto a sheet file, it does not display. Reading up on this from Autodesk, it states that I must apply a display configuration override on the sheet, to that xref, to show the live section (http://docs.autodesk.com/ARCHDESK/2011/ENU/filesUsersGuide/WScedd0d2069f88934b1c260fa2565f2a6-7fe6.h...)
However, I right click on the xref as asked, but it does not give me the option to do this.... something is wrong?
Right click on the xref and select "Edit Object Display". In the dialog box that appears there's a check box to override the display configuration and a list of the display configurations in the source file. Select the display configuration you used for the live section display.
John
Thanks but I am not getting this:
- "right click on the xref" - Where? On the sheet file? On the view drawing? On the External references list in the view drawing?
- When I click on the xref in the sheet file, I do not get this dialog box, only when I click on individual xrefs that form part of the view drawing, then this option works...
Yes, the view drawing is where you should set a display override. Right click on the xref itself. The sheet drawing should display whatever overrides you have set in the view drawing.
John
Thanks - and set it to what - any override of my choice or is a particular override required to get the live section to work? There are many x refs that make up the view drawing, do they all need to be clicked on and overriden?
Well, I was wrong on two counts. First I misread your original post and thought you were trying to get the override to show in the view file. Secondly and most important live sections apparently don't come through as view overrides. I know I've done this before but it's been long enough I needed to try it again to remember the steps. You'll need the live section in your sheet file. Either create it there or copy the section line from your view file to your sheet file and recreate the live section. If the live section is dependent on any special display configurations you'll need to make sure they are also in your sheet file. I've just tried this on a recently completed project so this should work. Sorry for the confusion.
Note that live sections won't work on any xrefs that already have view overrides. So if you have any view overrides already on existing on some of the xrefs you'll need to remove them.
John
Thanks again. For some reason, when I set up the whole thing froms scratch, I got the live section to work on the sheet without having to change any display configurations or anything. I just re-built my view drawing, and that must have got rid of some bug or other!
What I'm trying to do now, which I've posted a topic in the visualization forum about, is to overlay a linework elevation onto the rendered live section, so effectively, I've got a 2d linework drawing which sits on top of a rendered live section, and thus creates an attractive elevation for planning purposes. But now, when I drag one xref on top of the other, it completely covers it. Not sure if there is a way I can get the background of the xref to be transparent so it doesnt cover the xref that is below?
