In my case, the scale of both blocks is fine, and they are both visible in model space. The dissappear in the view port. The view port has all layers on and thawed...
is there a variable that needs to be set differently?
this was never an issue in Arch. Desktop 2006. I've only started experiencing it now, that we upgraded all the way to AutoCAD Architecture 2011.
Any luck with your issue so far?
Thank you
If the drawing scale of the viewport is different from the drawing scale at the time of object creation, if the viewport's scale was not ever added to the elevation mark annotative content, and you have toggled off the display of all annotative content, then only annotative objects that have the same scale as the viewport will show and your elevation mark will not show in the viewport.
Thank you Mr. Koch - that was very helpful.
I have yet to fully grasp the concept of annotative scales, the meaning / implications of the lightning bolt and the lightbulb tools at the bottom right of Application window... but this was definitely a great start.
Best,
Lucia
