If you are looking for window object solutions, I posted a metric version in
a file in customer files. 23/9/08
I used masselements to model 2 corner windows and use ME's added subtractive
body modifiers to remove the brickwork.
Certainly not an automated solution but it works. I wanted a WO solution
rather than DWA.
DWA's also require some dedicated tutorialling to get their mystic science
but they can be powerful once you get it.
wrote in message
news:6333747@discussion.autodesk.com...
The other way I have tried is just butting up 2 windows at right angles and
then manually adding lines in plan view. Turn off sill (or cill ) which wont
intersect properly and manually add lines so that it looks as if it cleans
up. In model view not a problem as the opening cuts OK - if only windows
would mitre. Bit of a botch - I tend to cut and paste the whole assembly
between jobs.
