For some reason my annotative MVBLOCKS and MTEXT are not displaying in the correct viewport scale.
I created an MVBLOCK (TAG) in another drawing where the scale was 1"=100' (1:1200). My next drawing was 1"=150' (1:1800) and I thought I would be able to use the same TAG just making sure that the proper annotative scale was set. When the TAG is viewed through the viewport, also set to 1'=150', the TAG shows with the size set for 1"=100'. It is readily apparent when I delete the annotative scale of 1"=100' from the TAGS, they all disappear in the viewport. However they show at the correct scale in model space when set to 1"=150'.
I thought it might have to do with something when I created the TAG originally, but there is a TEXT string at the top of my legend and it also does not display at the correct scale.
Any suggestions as to what I am doing wrong would be greatly appreciated.
Tom
I guess a good nights sleep (5 hours) is all that I needed to solve this.
Not sure why this happens but the fix was relatively easy.
First make sure that the annotative objects have both scales. In my case 1"=100' and 1"= 150'. Then go to the VIEWPORT that has the incorrect display. Unlock it, and change the scale to the one you don't want (1"=100') , then immediately change it back to the scale desired (1"=150') and viola the annotative objects rescale to the proper size.
I believe that since I brought theLAYOUT in from a template that had the previous scale set to 1"=100' may have caused the issue.
Tom
