I have a question about spaces and manual property definition.
I use AutoCAD Architecture 2015.
We use a SpaceOjects.psd and have a manual property definition with a list that contains department numbers.
Now I would like to automatically match a department number, with the corresponding department name.
I have looked to the description of the list, and put the department name there, but I cant find the value to match for display in the property set definition.
Is there a way to link 2 lists? or any other way to solve the problem?
Thanks in advance
Solved by VitalyF. Go to Solution.
Please attach an example.
Try to use Statements "Select Case"
for example:
Select Case "[DepName]"
Case "depA" , "depB" , "depC"
RESULT = "[DepName]"&"-1"
Case "depD" , "depE" , "depS"
RESULT = "[DepName]" & "-2"
Case Else
RESULT = "--"
End Select
Where:
property "[DepName]" - Departament Name type "List"
property "[DepNumber]" - Departament Name + Number - type formula
Vitaly
