AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Right click customization gone awry...
2 REPLIES 2
BBP-Arch
448 Views, 2 Replies
Have a situation w/ ACA 2011:
For some unknown reason, the Right-Click Customization (RCC) has changed. No software has been installed, no new mouse, nothing new has happened. It was set so that when no object was selected it repeated the previous command, and when an object is selected, THEN I get the shortcut menu. Now it ONLY gives last command on right click.
Also, and this may or may not be related, Copy with Basepoint no longer works: an object in one drawing was selected, Copy With Basepoint clicked, basepoint clicked on. In next drawing Ctrl+V brings in text that was last copied from Outlook, NOT the recently selected object from the previous drawing.
The machine has been re-booted and the problem remains.
Any ideas?
Scott
2 REPLIES 2
pendean
in reply to: BBP-Arch
PICKFIRST variable got turned off?
BBP-Arch
Thanks! That did it!
”Boost
