All of a sudden I notice that when I open a file in Autocad Architecture, it shows the file creation date and not the actual last save date. Only thing I can think of is I reinstalled 3dsmax Design and I wonder if that changed something. I attached a screenshot for reference.
Any help or suggestions are appreciated.
Building Suite Premium
Win 7, ultimate
i7 1.86ghz, 4meg ram
ATI 5730
Solved by MichaelBussiere2. Go to Solution.
Solved by David_W_Koch. Go to Solution.
In this case the Date Modified can be in the same list as Date Created by right clicking on “name” or another column header as David mentioned. Please let us know within the community if this helped and if this answered your inquiry. Thank you.
Thank you that worked. Not sure how it got set to just "date created". Changing it back is saved from session to session.
