AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
moving project navigator projects to another PC
2 REPLIES 2
407 Views, 2 Replies
I am new to rhe project navigator, I have several projects I would like to move to another computor and I am not sure how to do this. I have searched but must not have used the right words in the search. What is the correct way to move or export these project and inport them into the other PC? Thank you!
2 REPLIES 2
jcp
As with all thing autocad there are many ways to move a project.
The simplest way is to move it the same way you would move any file to another computer.  When you open the project on the new computer for the first time it will recognize the project has been moved and will ask if you want to repath the files. Select yes and your done.
in reply to: jcp
Thank You!
I was not sure if there was a special way to do this to keep it all together or not. I will move as a standard package.
”Boost
