AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
391 Views, 4 Replies
Hatch Lag
Bad lag
pick a hatch - LAAAG... - drop the hatch (esc) - LAAAAG..., open hatch properties window - LAAAAAG, change hatch properties - LAAAAAAG, close hatch proerties window - LAAAAAAAAg
The problem is the RIBBON.  Minimize the ribbon down as small as possible and hatch operations become smooth.
4 REPLIES 4
pendean
Turn off HPDLGMODE, things calm down?
in reply to: pendean
HPDLGMODE set to "0", still laggy mclaggerton...  Interface programming problem.
pendean
Since as end users you and I cannot fix "Interface programming problem", let's keep trying more realistic ways to make it work better instead.
Explore this http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Optimiz...
Thank you for the cooling attitude and advice.
Your point is the whole reason for my post in this thread - ie. backing up and breaking things down to the simplest terms so that I can "accomplish what I am able to" and do my part only, no more, no less.
That is why I created this thread to share the tip of turning the ribbon completely off in order to speed up hatch activity.  If you have any other ideas, I'm open to suggestions.
”Boost
