AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Color pencil apperance
9 REPLIES 9
Message 1 of 10
1020 Views, 9 Replies
I have created a 30 page 8.5 x11 booklet, using Architecure 2012, for a campus mater plan. Now our priciples want to see it in a hand sketch format. I can do the lines with the visual style sketchy but how do I get the solid hatch colors to look like color pencil? I am assuming I will need to use Photoshop but just wondering if there is something I can do in Autocad Architecture.
Kory Skoog
CADD Technician
9 REPLIES 9
Message 2 of 10
John.W.Mumaw
If you're on subscription you should have access to Autodesk Impression.  It will import autocad files and do what you want.
John
John W. Mumaw
Timber Frame Designer
Lost Bent Woodworking & Design
Message 3 of 10
I downloaded Impressions 3 for Windows 7. I try to import and I get an error message saying drawing file is invalid. I have tried on other .dwg files and get the same message. Using Autocad Architecture 2012. WHat am I doing wrong?
Kory Skoog
CADD Technician
Message 4 of 10
pendean
I suspect it only accepts non-AEC DWG files: -EXPORTTOAUTOCAD and try again.
Message 5 of 10
in reply to: pendean
I tried it but still gives me the same error message.
Kory Skoog
CADD Technician
Message 6 of 10
pendean
Message 7 of 10
Yes. I installed it and followed the "Crash on Windows 7 Hotfix" text file. My thinking now is to unistall and install the program and do the Hotfix.
Kory Skoog
CADD Technician
Message 8 of 10
pendean
Seems to work fine here with R2012.
Message 9 of 10
Ok I figured it out. I had colors from the True Color palette. Impression does not accept them. I changed my colors to the Index Color palette and it worked. Thanks for all your help.
Kory Skoog
CADD Technician
Message 10 of 10
pendean
Thanks for sharing that tip.
”Boost
