AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Annotative Dimensions on a Tool Palette
2 REPLIES 2
445 Views, 2 Replies
Is there a way to to put annotative dimensions on the Tool Palette. When I copy and paste an annotative dimension to the palette it loses it's annotative property.
2 REPLIES 2
Is the dimstyle already defined in the file, and is NOT annotative perhaps?
Dean Saadallah
http://LTisACAD.blogspot.com
odin
This rediculous problem has existed since Annotative Scaling was introduced and nothing has been done to remedy it. If you import the Style via the DesignCenter the Annotative Scaling setting is imported but not via the Tool Palettes becasue the Tool Palette Tools store dimstyle settings directly in the .xml file where this property doesn't exist. If you are trying to create office standards for dimension styles via the Tool Palettes, you'll soon find that it's a horrible choice - office standards should come from .dwg or .dws files not some disconnected .xml file.
If you just have to make it work, you can insert the dimstyle as a block first or execute a lisp routine that builds the style in the current file.
Odin
”Boost
