AutoCAD Architecture Forum
Welcome to Autodeskā€™s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Accelerator Keys for right-click object-snap cursor menu do not work.
2 REPLIES 2
Dhrd
340 Views, 2 Replies
Accelerator Keys
My accelerator keys for the right-click object-snap cursor menu do not work. For example, I will be drawing a line and I will bring up the object-snap menu, then I will select ā€˜Eā€™ for endpoint snap, the ā€˜eā€™ will display in the dynamic input window and the snap does not work.
Does anyone have a fix?
2 REPLIES 2
pendean
in reply to: Dhrd
if you turn off DYNMODE does the problem go away?
Dhrd
in reply to: pendean
No, it doesn't
I uninstalled ACA 2013 - Beta service pack #1 and installed the service pack posted on the Autodesk Website a couple of days ago and that fixed th problem.
ā€Boost
