AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
2011 update
7 REPLIES 7
Message 1 of 8
726 Views, 7 Replies
2011 update
Wow! There seems to be a lot of people having issues with the update to acad2011 and ACA2011. Should we await the second update and avoid these problems, or what?
7 REPLIES 7
Message 2 of 8
We have multiple CAD stations, I ran the updates on two of them and have more problems after the updates.  The systems that I have not installed the updates on are running fine.  I would recommend waiting until the next update comes out unless you are currently having alot of issues.
Message 3 of 8
pendean
A good rule of thumb: if it does not list a problem you have that is affecting your everyday work then you should not install any update from anyone.
Message 4 of 8
in reply to: pendean
Dean, even from such a trusted vendor as Autodesk?
Message 5 of 8
pendean
We don't install updates from anyone unless it solves a problem we cannot live with, or everyone else has installed it a while back and report no issues related to simply 'installing them': this applies to Autodesk, Microsoft, Adobe, Norton, and more.
Message 6 of 8
What kind of problems?
We installed it, and are running fine. As always everything seems to run a little faster after a service pack. So we are happy.
Every piece of software will cause problems for someone, somewhere, after all.
Message 7 of 8
I'm just reading a larger than usual number of posts concerning issues some have had with the service pack, so I asked the question.
Message 8 of 8
joeldf
No problems here either.  It did fix the issue of causing an error report after closing - it was a known issue while using a digitizer tablet.
All better now.
Joel
”Boost
